Connected battery wrong (Dodge Dakota truck)
same thing happen to me HELP!!
hey i need some help the same thing happen to me i put the + to the - and the - to the + and smoke came out the fuse box under the hood put none of the fuses are burned just my radio dont work know more and the truck starts pretty fast but the battery level is 2 low and when i turned my lights on or signal light everthing dims down the level of the battery gets lower and lower and i turned the truck on and disconnected the + and the truck dies they told me thats how u can check if the alternators is working.do u know if i have to change any relays,fuses ,first before buying all the big stuff. i would really appreciate if u can help . thanks michael email me at (daboyz_from_tx@yahoo.com)
Split off from another Subaru-related thread because it is off-topic.
Relays and fuses won't affect your alternator output. Your charging system is not recharging your vehicle battery. There is nothing wrong with your starting system or engine ignition since you are able to turn over and start the engine and it runs fine other than it is running completely off of the battery.
Consult your vehicle service manual, or a Dodge Dakota message board, or your Dodge/Plymouth dealer to find out if a simple alternator swap will cure the problem. Dodge probably has an integrated charging system regulator built into their ECU but it's been years since I've owned a Dodge vehicle. This board is Subaru-specific.
Good luck fixing your truck.
Scoober02
11-24-2004 03:25 PM
esracer
08-07-2004 11:41 AM
NewShockerGuy
07-14-2003 06:34 PM
