Strange noise resonating through my intake-PLEASE HELP
This is my 2007 WRX. I just finished up a TGV delete install in which I took off the manifold. After reinstalling everything to spec, this strange noise began after the car warmed up a little. The sound come directly from the intake. I took the filter off and the sound remains. It also increases when I turn the wheel at a stop. I checked the belt and everything is good with it. I believe the steering pump is fine to. When you lightly rev the motor, just tapping the throttle is subsides but remains on during sustained rev or driving around. When I shut off the car it makes makes another noise to (see video). Is it possible that it is a bad bearing in the turbo? It is a vf48 with 10k on it. Could something have gotten into it while I did the manifold removal and caused the sound? I really need to figure this out because it's really annoying.
I wish I got your power steering cooler!
Turns out the sound is my power steering pump going out. Probably from running aggressive wheels up here in the mountains. However, I may have over tensioned my v belt, is it possible that 10 minutes of running an overtightened belt could have caused the pump to begin failing?
Does anyone know what is a good replacement for a wrx pump?
Hmmm, maybe mine will go away. My vbelt was very tight and I suspect that may have cause it to fail, but I don't see how ten minutes of idle would cause this to happen. I retensioned it to spec today.
LOL
I was scared something like that happened at first because I only had a small shop towel shoved in there while I was reassembling the manifold but took it out for a couple hours. I was wondering if something crawled into there and died and was plugging up my turbo! lol
Car Info: sold: 06 wrx
i over tensioned my belt too when i did the tgv delete and aps inlet install but my belt just broke luckily not my ps pump. glad you got it fixed.. so what are your mods and what did you end up with the tune?
mothman331
08-21-2007 07:57 AM
M4d_r3x
01-12-2007 11:24 AM
