Power steering fluid
Car Info: MY 04 WRX
can you use any type of P/S fluid? i checked the manual and it said that to use Dexron III Automatic Tranmission Fluid. is this a typo or i just read this wrong.
thanks in advance.
thanks in advance.
Straight as an arrow
Car Info: The Fit is gone!
Just use what the manual says to. How is that so hard? If youre having so much trouble go buy some from the dealer. Is it worth saving a couple dollars if you mess up the steering system because you were cheap?
apparently you're not into reading and finding out new stuff
who said i'm having trouble?.i brought up a question. dexron 4 is a new formulation introduced in 06, and the manual was written before 02 and specs dexron 3.
i suppose you're stuck in the 90s with your ride
NeRdY DoRkUs
04-17-2005 06:46 PM
kalasend
09-18-2003 11:06 AM
