Fumoto drain valve leaking...
Car Info: '02 PSM WRX
I just put on a fumoto drain valve on my car. It has the blue flex washer on it, and i put the crush washer that was on the car's bolt. when i screwed it in, it's angling slightly down and towards the rear of the car, not straight up. Any help in fixing the leak? thanks
Car Info: 2017 WRB WRX Premium
I used only the blue washer and not the crush washer and I have had the fumotovalve on my car over 35k miles with no leaks. Be careful not to cross thread the threads on the fumotovalve as well, since it is made out of brass, and your oil pan is made of steel.
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
sorry for such a n00b question, but what do you exactly mean by that?
It is easy to destroy the threads on the fumotvalve since it is made from brass. Brass is a softer metal than steel. So if you cross-thread the threads when trying to install it, you will be SOL.
Kurlee Daddee
(THE ORIGINAL)
well, it's not bent at an angle. It's just that the top isn't pointed straight up is what I meant. Sorry for the confusion, it's that the top (where the spring is) is pointed towards the back of the car.
I used only the blue washer. It leaked at first but then I let the car cool completely and gave it an additional tightening (the car was pretty warm when it was originally installed) and now everything is A-OK.
stg2lgcy00
08-31-2005 11:12 PM
