Check Engine Light!
Old 06-21-2011, 09:23 PM
SubyWrxGuy's Avatar
Location: Another world. Another time. In an age of wonder.
Car Info: Hybrid
Unhappy Check Engine Light!
Crap, turned on my car and the check engine light popped up! I just installed a zero/sports radiator cap the other day.... would that have anything to do with it?!
SubyWrxGuy is offline
Old 06-21-2011, 09:39 PM
03.23.67 - 06.14.13
ldivinag's Avatar
hey, if you are ever in the fremont area, i wanna test out my scanner tool... lemme know...
ldivinag is offline
Old 06-21-2011, 09:59 PM
SubyWrxGuy's Avatar
Car Info: Hybrid
BTW: Are radiator cap's supposed to go on the top or bottom?!
Old 06-21-2011, 10:00 PM
SubyWrxGuy's Avatar
Car Info: Hybrid
If it keeps staying on I will def let you know!
Old 06-21-2011, 10:02 PM
apetron's Avatar
You mean the reservoir up near your turbo?
You should have a matched set of caps for it to work best. If you upgrade the cap on the radiator, you should the same cap for the reservoir. Keeps pressure and temps consistent throughout the cooling system.
apetron is offline
Old 06-21-2011, 10:05 PM
St0ich's Avatar
Car Info: 2005 WRB wagon / 2006 Red Toyota Tacoma
disconnect the negative terminal on the car battery for a minute or two, reconnect the terminal and see if the CEL is still on...
St0ich is offline
Old 06-21-2011, 10:22 PM
Four vs Two's Avatar
Car Info: 335i & S1000RR
Make sure your gas cap is on tight.
Four vs Two is offline
Old 06-22-2011, 05:06 AM
2cam16's Avatar
Car Info: '01 Forester S
Scan it.
2cam16 is offline
Old 06-22-2011, 06:12 AM
CaliSuby's Avatar
My check engine light keeps coming up too and cruise control light ... Car feels fine, not one issue. Anyone know of an affordable place to get the car scanned? Co worker told me they charge up to 100$ to plug it in and tell you what the issue is.. How true is that because it seems a little high ...
CaliSuby is offline
Old 06-22-2011, 07:18 AM
SubyWrxGuy's Avatar
Car Info: Hybrid
Crap, I put an zero/sports cap on bottom reservoir above the radiator shroud....
Old 06-22-2011, 07:56 AM
slugrx's Avatar
Car Info: 04 psm wrx sedan
This is the only reason I still have my ap ha, easy to check and clear codes
slugrx is offline
Old 06-22-2011, 09:46 AM
SubyWrxGuy's Avatar
Car Info: Hybrid
Is it potentially dangerous to have one cap upgraded and the other the same? Thanks!
Old 06-22-2011, 09:54 AM
Lil' Slugger
k-dogg39's Avatar
Car Info: 05 WRB STi Wagon/00 BRP GC Sedan
Usually Napa or any good auto parts store will scan your car for free and give you the code.
k-dogg39 is offline
code3suby's Avatar
Car Info: 97' Dodge Cummins and an RSTI thingie
Bryan, I highly doubt its related to your radiator cap. A system is only strong as the weakest link, which would be the other one, so in essence there shouldn't be much of a difference.
The majority of times CELs are due to electrical things such emissions sensors misreading or going bad, cylinder misfires and the like. I can help you scan it on friday if you want
code3suby is offline
Old 06-22-2011, 10:00 AM
SubyWrxGuy's Avatar
Car Info: Hybrid
Thanks Paul you kick butt man! We need to chill anyway
The cap i replaced was rated @ a lower pressure that the cap on the top reservoir so i figured it should be fine...
I guess it has been a while since i replaced the spark plugs....
Quick Reply: Check Engine Light!
