Buzzing gear whine-like noise above 65mph
Old 02-15-2015 | 11:08 AM
Kaimino's Avatar
Car Info: a blue car.
Video%201_zps54pr76i9.mp4
This is from my friend's 06 while she was driving home in the snow when it was around 25*F. Hopefully this vid will help more with diagnostic. (if video doesn't show, right click on the "broken image icon" and open image in a new tab. Sorry, I'm a noob with sharing photobucket vids)
I was thinking either it's the transmission whining from the cold, fuel pump, or mounts, but I digress. My car makes the exact same noise when under 40*F and it goes away completely after a full warm-up, but the noise is apparent since 0mph while her's is at 65mph after it's been warmed up.
Any help appreciated, thanks!
Old 02-17-2015 | 01:11 PM
04GG's Avatar
If in doubt, FLAT OUT
No idea, but it doesn't sound good. Could be something simple like a heat shield rattle though.
Old 02-17-2015 | 07:17 PM
Kaimino's Avatar
Could it possibly be a throw-out bearing? My friend made that suggestion on the issue. Either way, you're right, it doesn't sound good at all as mine didn't make a noise that bad since I replaced my ps pump.
On the other hand, my friend said the noise never came back since then, so for now it should be ok. Thanks for your input!
Old 02-18-2015 | 01:09 AM
JelloChex's Avatar
aka FlukeWRX
Car Info: '03 WRX WRB Sedan
What section of the car is the noise coming from (Front, rear, wheels, transmission, diff, elsewhere)?
Have you done the simple checks already (like making sure all fluids have been checked and topped off accordingly or make sure nothing is dragging or loose)?
Old 02-18-2015 | 08:45 AM
04GG's Avatar
Check wheel bearings too - I had a whine like that only at around 75 with some minor vibration and it was a rear wheel bearing.
Old 02-18-2015 | 09:56 AM
pho_shizzle's Avatar
Car Info: MY00 GC6 BRP
That noise definitely isn't a good sign.
Old 02-18-2015 | 10:08 AM
odyss3y's Avatar
Car Info: 2002 WRX
sounds like it happens right after she shifts. does it happen in a single gear at all speeds or any gear at that specific speed?
Old 02-18-2015 | 11:25 AM
Kaimino's Avatar
Have you done the simple checks already (look like making sure all fluids have been checked and topped off accordingly or make sure nothing is dragging or loose)?
Waiting for a reply from her. She's way out of my range of assistance atm, so not much personal help I can give her.
Will do!
Apparently it happens with 5th gear too, but not sure about the rest. I'll relay this info to her.
In general, the noise hasn't come back since then. Better safe than sorry, though.
Old 02-18-2015 | 11:29 AM
Kaimino's Avatar
double post
fly2daskyee82
11-23-2006 07:40 PM
sopps
06-05-2005 11:07 PM
schiza
01-22-2004 11:10 AM
wrcsti
12-12-2003 05:22 PM
raazin
11-04-2003 05:17 PM
Quick Reply: Buzzing gear whine-like noise above 65mph
