Backyard lowbudget Sniper Rifle Project... need some help.
Friendly Neighborhood Ogre
Car Info: GUNATICS.COM
Hi.
Well, I decided to start a little project... I want to put together a sniper rifle for low cost. Yeah, I know... you get what you pay for, etc, etc. The only thing thats gonna be low budget is the scope. The rifle will probably be an M1A or an AR-15, so I need for it to mount on weaver mounts.
The biggest problem with scopes Ive tried is that they sight in just fine, but after a few shots the target isn't true anymore and that pisses me off. I'm looking to spend about 100-120 bucks on it, which is really low buget for a scope but I know there are some decent ones out there. I want some decent magnification, but most importantly I need for it to stay true, even after 1000 shots!
Does anyone have any suggestions?
This is the scope I had in mind... Couple people say it works well, but I wanna ask around before I buy it.
https://www.theknifeconnection.com/i...OD&ProdID=3227
Originally Posted by brucelee
Hi.
your rings might be the issue.
i am in the process of getting a savage model for "hunting and self defense" purposes.
and the leupold scope adds about 300-400 to the price of the rifle (i'm trying to get "package" deal with scope, biopds and a case with the rifle).
doesnt matter if you have a kick *** rifle but cant hit the target cause you cant see it...
Word, but I can't justify a friggin $500 scope... thats another pistol, it just hurts to think about it.
Dahveed aka Robin Hood
good backyard sniper rifle = .22 Magnum (WMR) bolt action rifle, with a heavy, soft barrel.
oh and you would want to run these through it: http://www.outlandsales.com/vmax.html
oh and a Swarovski scope FTW
I'm not going to use a .22, it will most likely be .308... I basically just need a scope that is pretty good but doesn't cost an arm or a leg.
Car Info: 05 STi
If it's going to be a sniper rifle you gotta get a .308. It fires far better at long range and has tons more knock-down power than a .223
http://sadlak.com/si_custom_sm_fitting.html If you want to get it custom fit.
These are the best mounts for the M1A and are used in combat units Army wide.
http://www.gokart.net/shop-utopia/mc..._m14mount.html
daniel,
i think your issue is not with the scope or the rings/mounts.
might be the rifle itself.
as you continue to fire with it, the barrel can get "loose" over the session.
also, your ammo has to do with it.
i mean unless your mounts are very loose, i dont see a scope going bad after shooting.
have you measured your groups at when the firearm is cold vs, a few rounds down the target?
what distances are you shooting at?
Originally Posted by Group B
sounds pretty loud for "backyard use", dontcha think???
I was kidding about shooting it in my backyard... What I meant was its a backyard project and Im going kinda ghetto.
I think I decided on a Nikon scope.. Its a little more expensive then I originally planned @ $280 on sale (suggested price is $550)...
ldivinag, The scope I used before had major issues with its adjustment **** and I think the kick of 5.56 was enough to screw with them... After a while the **** broke and I couldnt adjust it anymore. Whatever you do STAY AWAY FROM NC STAR products!!!
The Nikon is supposed to be the shizzle.
hey... it's for a "good" cause... right?
i started the build-up project for the 50 cal...
can you imagine the scope i need for that? 1000 meters???????
LOL......
no_way56
Hawaii Classifieds
16
02-11-2015 10:34 PM
Weak Sauce
02-15-2006 05:05 PM
