Anyone want to help me build a motor??? also machine shop recommendations
Old 10-05-2011 | 10:12 PM
cueballsi's Avatar
Car Info: 2002 WRX- MBP
Hey I-club.. i want to do a rebuild on an extra block I have.... I have build a honda motor befor, but I am a little intimidated by the boxer motor... any help or recommendations would be appreciated...
Also, any local machine shop recommendations? I am in Fremont.
Lastly, what is your take n torque plates??? are they a must while boring and honing a motor???
Old 10-05-2011 | 10:55 PM
OneManArmy's Avatar
General Pimpin'
If you're in fremont I'd talk to Mike. I am pretty sure they changed machine shops last year and it seems to me that the motor in the "L" is holding up pretty well. I can recommend some but I don't know exactly what machine work you need.
As for the rebuild... books. Buy good books. Look at EVERY youtube link you can find on building suby motors. Read and ask questions. NASIOC has TONS of info on the subject.
Mostly... good luck!
Old 10-06-2011 | 12:09 AM
Lowend's Avatar
Best machine shop I've found
Replika Maschinen, Inc - Santa Clara, CA
In Santa Clara. Not cheap... and you get what you pay for.
Yes you need torque plates... for the extra $40 it costs compared to the couple thousand you'll have into the motor why wound anyone cheap out?
I'll also suggest coated main & rod bearings from Polydyn
Old 10-06-2011 | 12:11 AM
Unit 91's Avatar
i-Club Sympathizer
We use Clark's in Cupertino. They're good.
Old 10-06-2011 | 02:25 PM
cueballsi's Avatar
thansk for the input guys... I am reading that lot of people are using ACL Race bearings... they have a .001 additional clearance option....
Any key thing about running larger tolerances??? The theory i have read is that you run thicker oil and also it should help prevent spinning a rod...
Old 10-06-2011 | 02:45 PM
LifePlaza's Avatar
I use Comptech PRS in Sacramento, Jim and Tony are the best guys around if you want anything race engine related.
Old 10-24-2011 | 03:08 PM
cueballsi's Avatar
is this differant than the ACL race bearing coating??
Old 10-24-2011 | 05:40 PM
Lowend's Avatar
Maybe I'm not looking in the right spot, but the ACL's don't look like anything special to me
The Polydyn treated bearings have a dry-film lubricant baked onto them. Makes the bearings live a lot longer during oil starvation situations, like start-up or hard cornering when the oil sump gets uncovered
Small investment for a lot of durability
Old 10-25-2011 | 12:17 PM
pete's Avatar
Car Info: 07 STi, 02 F150-FX4, 04 ZX-636, 07 990 SuperDuke
What are you plans for the motor? Sleeves? What brand/type of pistons? If you go with cosworth pistons I've got their cir clip installer tool and a proper 99.5mm ring compressor, might have a piston pin puller tool around somewhere as well.
Do you plan on having the machine shop do all work and assembly of the short block? There's lots of things to think about when you're building up a new block.
Old 10-25-2011 | 12:20 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
We build mild to wild and use various machine shops for a particular build.
Feel free to pm us for a quote, to answer questions, etc.
Paul
Old 10-25-2011 | 05:43 PM
eastbaysubaru's Avatar
Motor:
Engine:
-Brian
Old 10-25-2011 | 07:42 PM
Lowend's Avatar
Old 10-26-2011 | 03:08 PM
pete's Avatar
Motor:
-Brian
Motor - Definition and More from the Free Merriam-Webster Dictionary
Definition of MOTOR
2: any of various power units that develop energy or impart motion: as
a : a small compact engine
b : internal combustion engine; especially : a gasoline engine
c : a rotating machine that transforms electrical energy into mechanical energy
bikelok
06-04-2014 01:02 PM
k3k0a
09-18-2013 02:08 AM
1JavaBlk_in_Sac
08-10-2011 11:29 PM
RallyWagon
10-29-2007 05:57 PM
boredracer
07-26-2007 03:31 PM
