Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
what's the max boost psi on stock internals
Old 12-20-2002 | 04:23 PM
brucelee's Avatar
Friendly Neighborhood Ogre
Car Info: GUNATICS.COM
Re: what's the max boost psi on stock internals
Originally posted by rednek wrx
im running a VF 22 turbo and sometimes the boost will climb up to 18-19 psi, is this risky
Whoa!! On an EJ25?
Or is this an EJ20? 18lbs isn't too risky on an EJ20, but it is a little high. I'd be worried about the tranny before I worried about the engine.
Old 12-24-2002 | 01:13 AM
old_duwel's Avatar
Car Info: 93 WRX Wagon (Silver)
Originally posted by N/A
1.3Bar in a 2.5RS-T would kick ***! Hmmm maybe after changing out all of the internals first.
hey N/A check your PM
Old 12-29-2002 | 11:40 AM
stealth-wrx's Avatar
previously i took my motor to 20-22 psi with nitrous and it was fine. i would not suggest that but as long as you dont lean out you will be fine. be carefull.
Old 12-30-2002 | 07:07 PM
WickedRydaX's Avatar
Car Info: Black WRX, X.S. turbo back exhaust, X.S. cold air, and a lot of plans
I have a friend that didn't know how to work his boost con. and he was running 2 bar on stock everything just about. Well to end this story, he got a new engine.
Old 12-31-2002 | 09:59 AM
what turbo did he have to run 2 bar? definately not a stock turbo or an ihi turbo
Old 01-01-2003 | 10:47 AM
Not sure, and the boost con. was set to 2 bars, so what the turbo was really pushing in another story.
Old 01-06-2003 | 11:08 AM
cRayZee's Avatar
1.3 bar is what my engine is maxing out on, im thinking about getting a air/fuel gauge to prevent leaning it out on some bad gas
The common AFR gauges out there are for narrow band O2 sensors and are not that accurate. But very useful if you match it with an EGT gauge and don't let it get too hot.
basically...
lean = high egt's
rich = lower egt's
-vic
Old 01-12-2003 | 09:58 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
i'd rather get an EGT than an air/fuel meter. unless you get a wideband o2, the regular autometer air/fuel meters aren't very accurate at all.
Quick Reply: what's the max boost psi on stock internals
