Fuel pressure without a RRFPR?
I was curious what fuel pressure everyone is running at with their RS-T setups? I'm not going to be using a RRFPR so I wanted to know what fuel pressure the rest of you non rising rate owners were using? Is 34 pounds a good amount?
Adam - if you are running 38 psi at idle, and 53 psi at OT with 8 psi of boost, you do not have a 1:1 FPR..you ahve a 2;1...that being said, that is an excellent FPR to use.
Adam
Z-1 Performance
www.z1auto.com
N/A: what setup are you planning on running, and how much boost initially? other mods: injectors, engine mgmt....they all play into the picture. Persoanlyl, I'd pick a 2:1 fpr over a piggyback like a SAFC any day, at least with stock injectors.
Adam
Z-1 Performance
www.z1auto.com
Dan
I'm borrowing a friends pc right now. Moving sucks.
Link2, WRX injectors for now switching to a set of larger 550cc injectors later on, the SCC project 2.5RS's turbo kit, GTR fuel pump, dual feed fuel rails, and a SARD FPR. With good enough engine management there should be no need to have a rising rate shouldn't there? I've owned alot of turbo cars before and never had to run a RRFPR before. Just wonder if this is something specific to the RS-T then.
suby_dude
02-12-2008 01:28 PM
impreza7
28
10-21-2003 10:13 AM
buraddo
08-15-2003 01:37 PM
silverscooby
02-18-2003 07:29 PM
