Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
Forester FI, questions, suggestions, help?
Old 02-23-2004 | 04:27 PM
What year is your Forester? If it is a SOHC EJ25 model, then your engine is identical to the RS motor from 2000 and up. You can use any and all turbo parts, kits, and mod info for those cars. Search for RSt" "RS-T" and read all the threads in this forum for a wealth of info.
Sorry for not seeing this before.
Old 02-23-2004 | 07:26 PM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
Yeah I don't know what happened. I didn't see it either.
wierd. I check this forum everyday.
Well, BAN is right, anything from a 2.5RS should fit the motor. Exhaust of course, is a bit different and a FMIC piping would be a little different.
But to answer some of your questions and add some other advice.
CAMS CAMS CAMS
they do amazing things for these motors. I run a ludespeed turbo kit (Stage I kit with StageIII turbo). With the only other mods being a lightened flywheel, COBB Cams, and Borla headers I was pulling better times than people with Stage II cars. I was doing that with a trunk full of tools and parts. When I added 550cc injectors, programable MAP sensor and a boost controller I ran my current PB of 13.2@102MPH. That was with a bent camshaft (due to a previous timing belt tensioner failure) and still no intercooler. I did it at 11psi with no det, TONS OF FUEL (they could smell my car in the stands) and some boost timing retard.
I run my car daily on 8lbs of boost and 91/92 oct gas. I just had the local Suby mechanic take it apart and take a look at everything. He said the pistons looked almost brand new with no black carbon deposits. <------- I don't run the cheap gas company's gas.
@8lbs I have about 4 degrees of timing being pulled and I don't experience any detonation. Not quite as rich as before; tuned some of it out.
TURBO
I love the power my turbo can create.
I don't love the lag.
my turbo is a garrett T3/T4 (.63 turbine/.60 compressor) it is NOT a ball bearing turbo. I wish it was.
In my oppinion, a turbo of the same flow characteristics with less lag (ie ball bearings) would be the best turbo for this motor.
Boost is a function of back pressure. My lower back pressure from my headers and 3" exhaust is great for the higher HP numbers but it does increase my lag a bit. I have not yet wrapped my headers to see if it makes a difference. I know it will, though. Maintaining the stock exhaust manifold with net less lag, but lower peak HP numbers. If you plan on AutoX-ing your car then it would probably do you well to leave the stock manifold on there.
Cool thing is that these turbos can be purchased on ebay for about 400 bucks. If you desire less lag, the Stage I turbo had a .60 turbine to give it faster spool time, but the increased back pressure and excessive turbine speed limit the peak HP.
TWIN TURBOS
there have been a couple TT setups out there. Forced Air Tech or somebody has a TT setup. It uses twin GT15's and is capable of over 500 HP. The turbos spool up in the teens to twenties. A crazy ride I can imagine. However, boost control is difficult and boost spikes and creep are apparent with TT kits. Not just that, but they are freaking expensive.
As far as going you own route: I never go with what has already been tried and tested. I always modify and fabricate my own stuff. My ludespeed kit was only a stepping stone for what I've done since then. Tom @ Ludespeed had to make a few things to my requests that weren't normally in the turbo kits.
I would really recommend an aftermarket engine control system (Link or Hydra Nemesis or Unichip or something) if you want to make real power. IF you are happy with 280 crank HP then don't worry about it, the stock ECU works fine.
that's my input.
Later,
Dominic
One last thing:
DO NOT USE A FACTORY WRX TURBO!
They suck. The turbine is so small they can't create crap for HP because the back pressure is so high that the engine is VERY prone to detonation. If you wanted to use WRX components, I would say to get the new turbo Forester cross member, WRX headers and an FP green turbo (the smaller 7cm) with a FMIC. That would be an awesome setup in my opinion.
Old 02-24-2004 | 03:03 AM
ImprezaRSX's Avatar
Big Baller
if you're not into the peak and you want low to midrange:
.60/.60 will work good with the stock exhaust manifold. all you need is a set of custom up and downpipes. Tom will still make'em at 400 bucks for the set. You just gotta ask nice. The T3 super 60 uses the standard ford T3 flanges, right? IF so, it'll bolt right up to these up/dp's.
If you're looking to spend as little as possible, it isn't as cost efficient as some would like to think to use the WRX stuff. If you already have a T3 turbo...
Things I think you'll need:
UP/ DP
Wastegate (unless that's built into the T3 you got) Tom's come with the external wastegate setup.
Oil line to feed turbo
Tap valve cover or run drain to oil pan.
Voltage Clamp (VC2 From Split second)
RRFPR (7:1 from Vortech)
Fuel pump (STi or Walbro- STi is quieter and more reliable)
Charge pipe with BOV (I might have one available real soon!!)
Intake pipe.
Silicon hoses
Hose Clamps.
1/2" Tees for heater core supply (water to turbo)
Boost gauge to see what the hell is going on.
Colder Plugs BKR7ES-11 (NGK)
bunch of hoses and vaccum lines to run wastegate, BOV, Boost gauge, cruise control, RRFPR, PCV (need a 3/8" checkvalve for that too)
Cruise control relocation
conical filter for intake pipe
Hobosexual
07-17-2014 09:17 PM
steen80
12-27-2013 06:45 PM
BajaNut
05-15-2003 01:36 PM
BajaNut
05-12-2003 11:20 AM
Quick Reply: Forester FI, questions, suggestions, help?
