Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
fluttering noise 3500-4000rpms +
Old 05-06-2005 | 06:43 PM
Jizzo_02SubiWRX's Avatar
Car Info: 07SubiWRX
Exclamation fluttering noise 3500-4000rpms +
anyone know why there is a fluttering noise when im at about 35-4k rpms? it sounds like my intake is pushing out air. i've only gone to about 4000 rpms, an it does it. usually the fluttering does it at redline or at a higher rpm. mine does it under no load. any help is appriciated. thanks
Old 05-08-2005 | 02:12 PM
Blarg's Avatar
probably the wastegate. at lower RPM's it cycles to keep the turbo from overboosting and at WOT, it starts to cycle again when you hit your target boost.
it becomes really obvious with aftermarket downpipes. You really only hear the fluttering in the car though...outside it sounds like turbo whine....like when a semi driving next to you gets on the gas.
Old 05-08-2005 | 05:05 PM
Car Info: 07SubiWRX
so is that bad?
Old 05-08-2005 | 05:14 PM
Blarg's Avatar
no, its normal. you just not usually hear it with the stock downpipe. just get used to it. some people adjust their wategate arm until the noise goes away...but then your WG doesn't work right...that noise means its doing its job...and you get spiky boost and power curves.
the stock downpipe has the WG port closed off...but in the bellmouth its open and has an shoots right into an "echo chamber".
you only hear the flutter inside the car..sort of sounds like a cricket in your exhaust....outside it sounds like turbo whine...like when you drive next to a semi and the driver gets on the gas...
Old 05-09-2005 | 12:10 PM
laoba's Avatar
Car Info: rx8
when i had a bellmouth, it sounded like a lawnmower when i got on it. i switched to a divorced, and now it sounds like there's a leak when i'm about 0.01~0.03mpa. like paper hitting a fan. is that normal with the divorced?
Old 05-09-2005 | 02:54 PM
Blarg's Avatar
probably what the WG sounds like through a divorced WG pipe. you'll hear it after you hit full boost, light throttle, and throttle lift-off.
Old 05-09-2005 | 06:15 PM
Car Info: 07SubiWRX
wat about my intake pushing out air. thats what is sounds like an looks like. it sounds like the waste gate isnt working an pushing air back out. also, my blitz bov isnt as loud. i think it's a vacum leak.
Old 06-06-2005 | 09:45 AM
Island Style's Avatar
Try resetting the ECU...
I know this may sound strange but I get this same phenomenon happening from time to time on my sti. Ever since I added my PDE downpipe, it would do this once in a while...everything would be fine, then all of a sudden, this fluttering would happen...at the time, when I did not have my Cobb AP, I would just reset the ECU and it would go away...now, with my cobb, I just reflash it using the controller....try it...
Old 06-07-2005 | 10:20 PM
Car Info: 07SubiWRX
I FIXED IT!!! all i did was adjust my blitz bov an now it works like a charm. go fig?
jinorazi
06-08-2008 01:53 PM
djtmalta
08-14-2005 12:02 PM
Normie J
07-15-2004 07:58 PM
hezlok
07-02-2004 10:18 AM
Darknight
11-04-2003 10:00 PM
Quick Reply: fluttering noise 3500-4000rpms +
