Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
2.5rs-t cooling system question
Old 07-19-2003 | 09:53 AM
240sxer's Avatar
im also worried about cooling in my car i have an ej20 running with my impreza L raditor.. any suggestions?
Old 07-20-2003 | 05:00 PM
240sxer's Avatar
no i havent. kinda pisses me off tho, it just idles so low it turns my car off, when im rolling toward a light and foot off the gas it just might shut off and it does! its even worst @ night, try going out of a parking out with this problem. everytime i have to stop or let off the gas to break it shuts off!!!!
no idea what it could be some say its because my car isnt properly tuned so imma have it tuned soon but for now i am going to up-load a new map see if that helps. owell i typed so much i forgot what else i was going to say :\
Old 07-22-2003 | 08:01 PM
fatcatturbo's Avatar
Car Info: DOHC Impreza RS soon to be TN
I'd have to say save your money, on those longer trips, if you sense you might be overheating in the next 5minutes or so, just turn your heat on and fan it to 4 for a couple of minutes, you'd be surpripsed of the dissipated heat you can get out of there
Old 07-26-2003 | 02:10 PM
Just call 1-800-RADIATOR (no, seriously) and ask them what they have. You can get a larger capacity aluminum radiator from them relatively cheap.
However, it's not really necessary. Use Water Wetter, keep an eye on your guage, and you should be fine.
Old 07-26-2003 | 07:45 PM
Bugout's Avatar
Car Info: 09 WRX Sedan };-)>
hey about your idle problem, i would suggest that you check the MAP sensor. that was the prob in my boys eclipse, i think! you know i not much help, hahah sorry.
Old 07-27-2003 | 04:20 PM
Originally posted by MateoDelQueso
Kinda off the subject, but how well does Water Wetter really work?
Yes, it lowers coolant temps by abot 30 degrees F or so. Better living through chemistry!
Old 07-27-2003 | 05:01 PM
Jejunum's Avatar
do we have real data besides theirs backing it up?
anyways i bought some today - how can i drain my radiator enoguh to add some (its filled all the way at the top)
i saw the procedure to drain the radiator completely and it looks messy! ideas? (just to add one bottle of watter wetter
Old 07-27-2003 | 05:35 PM
Gary Sheehan runs it in his car. I asked him about it and he says it's lower by about 30 degrees on his guage. That and Redline's data was good enough for me.
