Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
1993 Impreza L : Turbo project (Engine Swap?)
Old 01-22-2004 | 10:03 PM
Welcome! Ummm... where to start...
Basically, just spend some time browsing through the aftermarket turbo forum, as well as the factory turbo forums. You'll learn more that way, and faster, than by us posting up advice and info in this thread. Shorthand answers are, do a swap for reliability and turbo what you have to be creative/unique. FYI, any motor that was ever in a Legacy, Forester, or Impreza will fit in your car. The most important of these are EJ20 variants and the STi and turbo Baja/Forester motors. You'll probably find that those swaps are every bit as easy as the Honda swaps you're used to as long as you do a little research before beginning. Good luck!
Old 01-31-2004 | 11:52 PM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
Getting a wrecked WRX front clip is deffinitely a good way to go. You have all the wiring, all the engine, all the fun.
also, isn't a 93 L only front wheel drive??
Sounds like you're going to need some more parts to make this swap worthwile.
What good is all that power with all the grip?
supermoose
02-05-2007 10:29 PM
Drew1185
11-14-2006 10:14 AM
theanimestore
Cars For Sale
10-03-2004 12:41 PM
vkracing
Cars For Sale
02-16-2004 08:50 AM
Quick Reply: 1993 Impreza L : Turbo project (Engine Swap?)
