1.8 Liter Impreza Engine
not sure on the ratings.. I know you can get the full kit from flat4engineering.com for like $2600 thats everything...
Basic 93-02+ PDM turbo kit (1.8, 2.2, and 2.5L engines, FWD, AWD, manual and auto trannies)
Included:
Ceramic coated up, down and inlet pipes, inside and out. A 2 inch up-pipe and 2 1/2 inch cat-equipped downpipe is standard. (trackpipe avail.)
IHI VF11 Turbo, 4-5lb waste gate actuator (internal wastegate)
high volume fuel pump
Turbo inlet and K&N cone filter
Oil accumulator and supply lines
Necessary gaskets, hoses, and brackets
Wastegate (internal wastegate standard on base kits)
Blow-off valve
necessary oil and coolant lines with adapters
Welded oil pan with turbo oil return line
Spark plugs (colder heat range)
All necessary bolts, clamps, hoses and hardware. It's complete, folks!
Included:
Blow-off valve
Roundhead08
03-26-2007 01:48 AM
